Any word on fixing the NB Miata trigger detection?
I have the same issue with oil press on Analog in 3 . In the same time egt shows 1125 temp .
log 22.emublog3 (147.8 KB)
ok v3.063.emub3 (71.0 KB)
after update firmware oil press working properly, many thanks!
@Jadzwin_ECUMASTER
Please give me the ability to disable the engine start immobilizer when the cruise control is on and the brake/clutch switches are missing.
I want to learn something before making any changes.
Is the fuel temperature sensor output used in the fuel model like the IAT sensor, or should I manually edit the fuel temperature correction map?
This future shoudl be disabled in my opinion but id you insist create brake switch permanently on on any free can analogue
You need to fill out the correction table. There is no built in fuel temp. correction
Thanks for clearing that
I add an option to disable the check. However without the brake switch you want be able to disable cruise control when braking
Notieced similar thing. But cant compare to other version.
I created my fuel table without a fuel temperature sensor, but I’m planning to connect one. What default fuel temperature value does the ecu assume in the fuel calculation so I won’t need to retune my VE map?
The fuel temperature is not a part of fuel calculation.
So by default the correction is 0%.
This is very interesting. I’m tuning a normally aspirated EJ20 with aluminium intake manifold. My intake air temperature at idle in summer frequently exceeds 60°C and as you are probably aware the steel fuel lines and rails are exposed to all of the heat soak between the manifold and the block.
I have a lot of trouble stabilising my low speed, low load AFR.
Could fuel temperature be a factor?
Fueltemp may be a small factor. But i am sure ur real problem is more the heat soaked sensor. Means sensor value is higher than actual iat and ur base fueiling gets messed up.
There are some threads in this forum about this topic…just search for it.
It would be great to have the abbility co modify the predefined CAN streams. For example:
Cruise control on E46 is working physically, but it does not turn on the cruise icon. I can do this via a custom message in user defined stream, but the icon flickers because of CAN conflicts (predefined stream vs custom).
Bit slow to respond to your input into my fuel temp question, regarding the IAT heat soak, just wanted to say thanks, I’ve been giving it a lot of thought. I’m gonna see if I can get a K-type in there without it being subject to heat soak and run some comparison tests.
It is not possible. However if you provide me information what to add I can inplement it for new build
Hi. You previously mentioned that limited memory prevents adding Long Term Fuel Trim to the EMU Black. I was wondering: could this be bypassed by using an EDL? Could the firmware be updated so that LTFT becomes an option only when an EDL is enabled in the settings? If no EDL is detected, the feature would simply stay ‘grayed out.’ I’m just curious if using the EDL’s memory this way is technically possible.
If there were a real-time autotune function capable of automatically applying corrections every x measures per cell, it would save me time when tuning low-load VE map. Of course, this would require using a laptop with the V3 software for this functionality.
Has anyone confirmed Fueal Pressure Error (kpa) works on V3 ?
V2 was Fuel Pressure Delta channel, working just fine.
V3 is stuck at 0kpa (working fuel pressure sensor ofc)
